StarTech.com 7m White Cat6 Patch Cable
Quicklinx: CC44WS00 Mfr#: N6PATC7MWH
Length: 7m
Colour: White
47 In Stock
£10.35 ex VAT
£12.42 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. This 7-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. Plus, the cable features a durable white PVC jacket that enables you to color code your network cable runs as needed.
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
StarTech.com 7m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, White, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC7MWH) - patch cable - 7 m - white
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless, minimised Near-End Crosstalk (NEXT)
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7 m
308 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
CC44 StarTech.com 7m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.40
CC44 StarTech.com 7m Green Cat6 Patch Cable In Stock £6.07
CC44 StarTech.com 7m Gray Cat6 Patch Cable In Stock £10.16
CC44 StarTech.com 7m Red Cat6 Patch Cable In Stock £6.02
CC44 StarTech.com 7m Yellow Cat6 Patch Cable In Stock £6.02
CC44 StarTech.com 7m Orange Cat6 Patch Cable In Stock £6.15
CC44 StarTech.com 7m White Cat6 Patch Cable In Stock £10.35
CC44 StarTech.com 7m Purple Cat6 Patch Cable In Stock £6.25
Length: 7m
Colour: White
