StarTech.com 7m Red Cat6 Patch Cable
Quicklinx: CC41WS00 Mfr#: N6PATC7MRD
Length: 7m
Colour: Red
13 In Stock
£6.02 ex VAT
£7.22 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. This 7-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. Plus, the cable features a durable red PVC jacket that enables you to color code your network cable runs as needed.
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
Startech 7m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Red, Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC7MRD) - patch cable - red
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wires per Cable
4 wires
Snagless
Cable Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
4 wires
Pairs per Cable
8 pairs
Plated Connector
Gold
Snagless
Cable Length
7 m
308 g
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
CC41 StarTech.com 7m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.20
CC41 StarTech.com 7m Gray Cat6 Patch Cable In Stock £10.16
CC41 StarTech.com 7m Red Cat6 Patch Cable In Stock £6.02
CC41 StarTech.com 7m Yellow Cat6 Patch Cable In Stock £6.02
CC41 StarTech.com 7m White Cat6 Patch Cable In Stock £10.20
CC41 StarTech.com 7m Purple Cat6 Patch Cable In Stock £6.02
Length: 7m
Colour: Red
