StarTech.com 7m Purple Cat6 Patch Cable
Quicklinx: CNDHWS00 Mfr#: N6PATC7MPL
Length: 7m
Colour: Purple
£6.02 ex VAT
£7.22 inc VAT
Make Gigabit Ethernet connections with PoE support. This Cat6 cable delivers reliable Gigabit network connections, which ensures high-performance capability for your demanding Ethernet applications.
This 7-meter purple patch cable is perfect for use in network conduits and raceways. The cable is intended for longer distance applications, such as running up a post or throughout the office from a hub to a wall jack.
For easier network installations, the Cat6 patch cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The cable also features molded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
Get the highest value for your cable investment with the Cat6 Ethernet cables. Each of the patch cables is manufactured using high-quality copper conductors and they are carefully constructed and tested, to keep Near-End Crosstalk (NEXT) well within acceptable limits.
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet and 4K or 1080p video streaming, using cables that include 24 AWG copper.
You can rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Startech 7m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Purple, Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC7MPL) - patch cable - 7 m - purple
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless
Cable Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Purple
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Snagless
Cable Length
7 m
308 g
Purple
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
CNDH StarTech.com 7m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £9.95
CNDH StarTech.com 7m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.20
CNDH StarTech.com 7m Green Cat6 Patch Cable In Stock £5.93
CNDH StarTech.com 7m Gray Cat6 Patch Cable In Stock £10.20
CNDH StarTech.com 7m Orange Cat6 Patch Cable In Stock £6.15
CNDH StarTech.com 7m White Cat6 Patch Cable In Stock £10.20
Length: 7m
Colour: Purple
