StarTech.com 7m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable
Quicklinx: FBZCWS00 Mfr#: A50FBLCLC7
Length: 7m
Colour: Aqua
£24.51 ex VAT
£29.41 inc VAT
This OM3 LC to LC Multimode Duplex Fiber Optic Patch cable features 50/125 micron fiber and supports high-bandwidth data transmission over a 10 Gigabit Ethernet connection.
With laser-optimized multimode fiber (LOMMF), the patch cable is ideal for connecting 850 nm Vertical Cavity Surface Emitting Laser (VCSEL) and LED sources. The high-speed connectivity on the aqua fiber-optic cable provides a high-bandwidth solution for your data centers or high-density applications.
Each OM3 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, this fiber-optic cable ensures minimal smoke, toxicity and corrosion when exposed to high sources of heat, or in the event of a fire. It's the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
  • Reliable Performance
    This fiber optic patch cable is engineered to deliver consistent high-quality data transmission, making it suitable for demanding networking environments.
  • Halogen-Free Construction
    The Low Smoke Zero Halogen (LSZH) material ensures that the cable minimizes harmful emissions in the event of a fire, promoting safety in various settings.
  • Efficient Connectivity
    With LC multimode connectors on both ends, this cable allows for streamlined connectivity between devices, reducing data loss and ensuring optimal performance.
  • Dual Fiber Strands
    Incorporating two fiber strands, this cable supports simultaneous data transmission and reception, enhancing overall network efficiency.
  • Compliance with Standards
    Adhering to OM3 standards and RoHS directives, this patch cable meets essential regulations for quality and safety in fiber optics.
StarTech.com 7m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable - Aqua - 50/125 - LSZH Fiber Optic Cable - 10Gb (A50FBLCLC7) - patch cable - 7 m - aqua
Patch cable - OM3
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, Laser-optimized multimode fibre (LOMMF)
Length
7 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Aqua
Network Cable Type
Patch cable - OM3
Duplex fibre optic
Multimode
Jacket Material
Fibre Qty
2
50 / 125 micron
Length
7 m
Aqua
Connector
RoHS
FBZC StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £32.96
FBZC StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £16.82
FBZC StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £23.93
FBZC StarTech.com 7m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable In Stock £24.51
Length: 7m
Colour: Aqua
