OM5 FIBER CABLE: The OM5 LOMMF cable is optimized for 40/100 Gbps fiber optic networks. Extended 850-953 nm wavelength support enables SWDM (Short Wavelength Division Multiplexing) for greater channel isolation.
QUALITY CONSTRUCTION: LC/LC-UPC ends for better return loss than PC polishing - Color-coded connectors for polarity - Fiber core insensitive to bending, Aramid sheathing for a maggione bend radius.
RELIABLE: individually tested for guaranteed performance (testing included). LSZH sheathing emits low toxic fumes in case of combustion. Safe in poorly ventilated spaces. Attenuation value <2.4 dB/km meets/exceeds standards.
WIDE COMPATIBILITY: OM5 multimode cable supports 10/40/100G networks, compatible with OM4/OM3. High resistance to microbending facilitates bending in complex installations, ideal for fiber switches/servers, SANs and SFP+/QSFP+/QSFP28 modules.
SPECIFICATIONS: OM5 - LC/LC (UPC) - 50/125µm - 850-953nm VCSEL/1300nm LED - Modal bandwidth: 4700MHz.km (850nm), 2470MHz.km (953nm) - Insertion loss: =0.3dB - Return loss: =30dB - Cable Ø: 2.9mm - Bend radius: 3-6cm
High-speed connectivity
Experience fast data transfer rates of up to 100 Gbps, ideal for high-bandwidth applications and efficient data center operations. -
Enhanced durability
Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, ensuring a safer environment for all users. -
Optimized for laser
Equipped with Laser-optimized multimode fibers (LOMMF), this cable supports a wavelength range of 840/953/1300 nm, making it suitable for use with VCSEL laser light sources. -
Bend insensitive design
This cable's bend insensitive technology allows for a more flexible installation process and reduces the risk of performance degradation due to bending. -
Eco-friendly choice
Halogen-free construction not only contributes to a safer environment by reducing toxic emissions but also complies with RoHS standards, making it an eco-conscious choice.
- StarTech.com 7m (22ft) LC to LC (UPC) OM5 Multimode Fiber Optic Cable, 50/125µm Duplex LOMMF Zipcord, VCSEL, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 7 m - green
- Patch cable - OM5
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Halogen-free, up to 100 Gbps data transfer rate, Laser-optimized multimode fibre (LOMMF), wavelength of 840/953/1300 nm
- Length
- 7 m
- Diameter
- 2.9 mm
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC/UPC multi-mode - male
- Connector (Second End)
- Green
- Limited lifetime warranty
- Network Cable Type
- Patch cable - OM5
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 50 / 125 micron
- Length
- 7 m
- Diameter
- 2.9 mm
- Green
- Connector
- RoHS
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 1.4 cm
- Shipping Weight
- 62 g
- -20 °C
- 60 °C
StarTech.com 15m LC/LC OM5 Fiber Cable | In Stock | £55.00 |
StarTech.com 1m LC/LC OM5 Fiber Cable | In Stock | £17.35 |
StarTech.com 20m LC/LC OM5 Fiber Cable | In Stock | £67.49 |
StarTech.com 2m LC/LC OM5 Fiber Cable | In Stock | £19.09 |
StarTech.com 3m LC/LC OM5 Fiber Cable | In Stock | £23.93 |
StarTech.com 5m LC/LC OM5 Fiber Cable | In Stock | £28.27 |
