StarTech.com 7m LC/LC OM5 Fiber Cable
Quicklinx: HHXBWS00 Mfr#: LCLCL-7M-OM5-FIBER
Length: 7m
Colour: Green
10 In Stock
£34.76 ex VAT
£41.71 inc VAT
OM5 FIBER CABLE: The OM5 LOMMF cable is optimized for 40/100 Gbps fiber optic networks. Extended 850-953 nm wavelength support enables SWDM (Short Wavelength Division Multiplexing) for greater channel isolation.
QUALITY CONSTRUCTION: LC/LC-UPC ends for better return loss than PC polishing - Color-coded connectors for polarity - Fiber core insensitive to bending, Aramid sheathing for a maggione bend radius.
RELIABLE: individually tested for guaranteed performance (testing included). LSZH sheathing emits low toxic fumes in case of combustion. Safe in poorly ventilated spaces. Attenuation value <2.4 dB/km meets/exceeds standards.
WIDE COMPATIBILITY: OM5 multimode cable supports 10/40/100G networks, compatible with OM4/OM3. High resistance to microbending facilitates bending in complex installations, ideal for fiber switches/servers, SANs and SFP+/QSFP+/QSFP28 modules.
SPECIFICATIONS: OM5 - LC/LC (UPC) - 50/125µm - 850-953nm VCSEL/1300nm LED - Modal bandwidth: 4700MHz.km (850nm), 2470MHz.km (953nm) - Insertion loss: =0.3dB - Return loss: =30dB - Cable Ø: 2.9mm - Bend radius: 3-6cm
  • High-speed connectivity
    Experience fast data transfer rates of up to 100 Gbps, ideal for high-bandwidth applications and efficient data center operations.
  • Enhanced durability
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, ensuring a safer environment for all users.
  • Optimized for laser
    Equipped with Laser-optimized multimode fibers (LOMMF), this cable supports a wavelength range of 840/953/1300 nm, making it suitable for use with VCSEL laser light sources.
  • Bend insensitive design
    This cable's bend insensitive technology allows for a more flexible installation process and reduces the risk of performance degradation due to bending.
  • Eco-friendly choice
    Halogen-free construction not only contributes to a safer environment by reducing toxic emissions but also complies with RoHS standards, making it an eco-conscious choice.
StarTech.com 7m (22ft) LC to LC (UPC) OM5 Multimode Fiber Optic Cable, 50/125µm Duplex LOMMF Zipcord, VCSEL, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 7 m - green
Patch cable - OM5
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, up to 100 Gbps data transfer rate, Laser-optimized multimode fibre (LOMMF), wavelength of 840/953/1300 nm
Length
7 m
Diameter
2.9 mm
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC/UPC multi-mode - male
Connector (Second End)
Green
Network Cable Type
Patch cable - OM5
Duplex fibre optic
Multimode
Jacket Material
50 / 125 micron
Length
7 m
Diameter
2.9 mm
Green
Connector
RoHS
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
1.4 cm
Shipping Weight
62 g
-20 °C
60 °C
HHXB StarTech.com 10m LC/LC OM5 Fiber Cable In Stock £44.98
HHXB StarTech.com 15m LC/LC OM5 Fiber Cable In Stock £56.38
HHXB StarTech.com 1m LC/LC OM5 Fiber Cable In Stock £17.78
HHXB StarTech.com 20m LC/LC OM5 Fiber Cable In Stock £69.18
HHXB StarTech.com 2m LC/LC OM5 Fiber Cable In Stock £19.56
HHXB StarTech.com 3m LC/LC OM5 Fiber Cable In Stock £28.58
HHXB StarTech.com 5m LC/LC OM5 Fiber Cable In Stock £30.22
Length: 7m
Colour: Green
