Connect an HDMI -enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDDVIMM7M 7m HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology. The cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high-performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
- StarTech.com 7m HDMI to DVI-D Cable - HDMI to DVI Adapter / Converter Cable - 1x DVI-D Male 1x HDMI Male - Black 7 meters (HDDVIMM7M) - adapter cable - HDMI / DVI - 7 m
- Cable
- Adapter cable - HDMI / DVI
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24
- Length
- 7 m
- Black
- Connector
- DVI-D - male
- Connector (Second End)
- HDMI - male
- Moulded
- Limited lifetime warranty
- Cable Type
- Adapter cable
- Interface Supported
- HDMI / DVI
- Technology
- Shielded
- 24
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 7 m
- Plated Connector
- Gold
- Moulded
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
StarTech.com 10m HDMI to DVI-D Cable - M/M | In Stock | £58.94 |
StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor | In Stock | £8.82 |
StarTech.com 3m HDMI to DVI-D Cable - M/M | In Stock | £9.75 |
StarTech.com 5m HDMI to DVI-D Cable – M/M | In Stock | £18.49 |
StarTech.com 15m HDMI to DIV-D Cable – M/M | In Stock | £28.49 |
StarTech.com 1m HDMI to DVI-D Cable - M/M | In Stock | £7.62 |
StarTech.com 1.5m HDMI to DVI-D Cable - M/M | In Stock | £11.20 |
StarTech.com 7m HDMI to DVI-D Cable - M/M | In Stock | £14.28 |
StarTech.com 0.5m HDMI to DVI-D Cable - M/M | In Stock | £8.02 |
