StarTech.com 7m Gray Cat6 Patch Cable
Quicklinx: B2WBWS00 Mfr#: N6PATC7MGR
Length: 7m
Colour: Grey
19 In Stock
£10.20 ex VAT
£12.24 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC7MGR Cat 6 patch cable (7m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Enhanced connectivity
    This 7m CAT6 Ethernet Cable ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors, providing superior conductivity and corrosion resistance.
  • Durable design
    Featuring a sturdy PVC jacket and strain relief, this network cable is built to withstand rigorous use, making it ideal for both home and office environments.
  • High-speed performance
    With a tested frequency of up to 500 MHz, this CAT 6 patch cable supports 10 Gigabit Ethernet speeds, ensuring fast and efficient data transfer for streaming, gaming, and other bandwidth-intensive activities.
StarTech.com 7m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Grey, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC7MGR) - patch cable - 7 m - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wires per Cable
4 wires
Snagless
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
4 wires
Pairs per Cable
8 pairs
Plated Connector
Gold
Snagless
Length
7 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
B2WB StarTech.com 7m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £9.95
B2WB StarTech.com 7m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.20
B2WB StarTech.com 7m Green Cat6 Patch Cable In Stock £5.93
B2WB StarTech.com 7m Gray Cat6 Patch Cable In Stock £10.20
B2WB StarTech.com 7m Yellow Cat6 Patch Cable In Stock £6.02
B2WB StarTech.com 7m Orange Cat6 Patch Cable In Stock £6.15
B2WB StarTech.com 7m White Cat6 Patch Cable In Stock £10.20
B2WB StarTech.com 7m Purple Cat6 Patch Cable In Stock £6.02
Length: 7m
Colour: Grey
