StarTech.com 7m CAT6a Ethernet Cable LSZH - White
Quicklinx: H15SWS00 Mfr#: NLWH-7M-CAT6A-PATCH
Length: 7m
Colour: White
10 In Stock
£26.93 ex VAT
£32.31 inc VAT
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
Available in a variety of lengths and colors, the shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
  • Robust construction
    The cable features a durable Low Smoke Zero Halogen jacket that provides fire safety and reduces harmful emissions during installation.
  • High speed capability
    With support for up to 10 Gbps, this cable is ideal for high-performance networking applications that require fast data transfer.
  • Advanced shielding
    Constructed with foil shielding to minimize Near-End Crosstalk (NEXT), ensuring clear signal transmission for reliable connectivity.
  • Strain relief design
    Equipped with strain relief features to enhance cable longevity by preventing stress and damage where the cable meets the connectors.
  • Compliance assured
    This cable adheres to RoHS, ETL, and ANSI/TIA-568.2-D standards, providing assurance of quality and safety in various applications.
StarTech.com 7m CAT6a Ethernet Cable - White - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 7 m - white
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7 m
240.9 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
20 cm
Shipping Depth
18 cm
Shipping Height
3.5 cm
Shipping Weight
249.9 g
Length: 7m
Colour: White
