StarTech.com 7m CAT6a Ethernet Cable LSZH - Black
Quicklinx: H154WS00 Mfr#: NLBK-7M-CAT6A-PATCH
Length: 7m
Colour: Black
11 In Stock
£9.24 ex VAT
£11.08 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 7m - Black - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • High-performance connectivity
    This patch cable is capable of delivering data transfer rates of up to 10 Gbps, making it ideal for high-bandwidth applications.
  • Safety-focused design
    The Low Smoke Zero Halogen jacket ensures that the cable emits minimal smoke and toxic fumes in case of fire, making it a safe option for various settings.
  • Robust construction
    With copper conductors and foil shielding, this cable is designed to withstand wear and tear while providing reliable signal integrity.
  • Effective crosstalk prevention
    Features including minimized Near-End Crosstalk (NEXT) help maintain a clear signal, improving overall network performance.
  • Power over Ethernet support
    This cable supports Power over Ethernet (PoE++) with a maximum input power of 100 watts, enabling multiple devices to receive power and data from a single connection.
StarTech.com 7m CAT6a Ethernet Cable - Black - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 7 m - black
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7 m
240.9 g
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
20 cm
Shipping Depth
18 cm
Shipping Height
3.5 cm
Shipping Weight
249.6 g
Length: 7m
Colour: Black
