CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 7.5m - Turquoise - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
Robust construction
This cable features a copper conductor and foil shielding material, providing reliable performance while protecting against electromagnetic interference. -
High compatibility
Compliant with various standards including RoHS, ETL, WEEE, and PoE++, ensuring compatibility with a range of devices and applications. -
Efficient design
Molded and snagless connectors enhance usability while minimizing the risk of damage, contributing to long-lasting performance. -
Excellent transmission quality
Tested frequencies up to 500 MHz, ensuring high-quality signal transmission and minimal Return Loss (RL) for optimal connectivity. -
Ease of installation
The 27 AWG wire gauge allows for easy handling and installation, making it a versatile choice for various networking needs.
- StarTech.com 7m CAT6a Ethernet Cable - Aqua - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 7 m - aqua
- Patch cable - CAT 6a - IEEE 802.3bt
- Technology
- S/FTP
- Shielding Material
- Foil
- Wires per Cable
- 8 wires
- Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
- Length
- 7 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Foil
- Jacket Material
- American Wire Gauge (AWG)
- 27
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 7 m
- 240.9 g
- Aqua
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
- Shipping Width
- 20 cm
- Shipping Depth
- 18 cm
- Shipping Height
- 3.5 cm
- Shipping Weight
- 249.6 g
