StarTech.com 7m CAT6a Ethernet Cable - Blue - CAT6a STP Cable - Snagless
Quicklinx: FSHRWS00 Mfr#: 6ASPAT7MBL
Length: 7m
Colour: Blue
10 In Stock
£13.44 ex VAT
£16.12 inc VAT
This CAT6a Ethernet cable meets all Category 6a cable specifications. It ensures reliable 10Gb connections between your network devices.
Tested for up to 500MHz frequency, each CAT6a cable is more than suitable for 10GBase-T Ethernet networks.
Built for quality performance, the cable features 100% copper and foil-shielded, twisted-pair wiring. The cable is designed to keep the data signals traveling through your network free from noise and interference. It's perfect in environments that are prone to large amounts of electromagnetic interference (EMI/RFI).
This CAT6a patch cable is built using 100% copper wire and is tested to comply with ANSI/TIA 568 C.2 Category 6a requirements. StarTech.com doesn't use copper-clad aluminum (CCA) wire which is subject to problems like weak power delivery, heat buildup, equipment damage and possibly fire.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The CAT6a Ethernet cable also features molded boots which offer strain relief by stopping the RJ45 connectors from bending at sharp angles. This reduces the risk of cable damage, which could decrease network connectivity and performance.
  • Robust construction
    The 7m CAT6A Ethernet Cable features a durable PVC jacket, designed to protect the internal wiring from damage and ensure longevity in various environments.
  • Enhanced performance
    With a tested frequency of up to 500 MHz, this cable supports reliable and high-speed data transfer, making it suitable for both home and professional use.
  • Effective shielding
    Incorporated RFI/EMI shielding minimizes signal interference, resulting in a stable Internet connection that is essential for high-bandwidth activities.
  • Easy installation
    The molded and snagless design of the cable prevents damage to the connectors during installation and removal, simplifying the setup process.
  • Power over Ethernet
    This cable is PoE ready, allowing users to transmit power along with data through the Ethernet connection, streamlining the setup for devices such as IP cameras and VoIP phones.
StarTech.com 7m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT7MBL) - patch cable - 7 m - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, strain relief, PoE ready, RFI/EMI shielding
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
25
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH - up to 500 MHz
FSHR StarTech.com 7m CAT6a Ethernet Cable - Aqua - CAT6a STP Cable - Snagless In Stock £16.11
Length: 7m
Colour: Blue
