StarTech.com 75ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 6BBHWS00 Mfr#: MXT101MMHQ75
Length: 22.9m
Hurry, only 2 left in stock!
£40.49 ex VAT
£48.58 inc VAT
This 75ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 75ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 22.9 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
22.9 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
22.9 m
Connector
Length: 22.9m
Price Range Ex VAT: 0 - 50
