Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH75WH Cat 6 Patch Cable (75 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable white PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Snagless RJ45 clips help protect your network connections
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port. The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance. -
100% copper for outstanding value
Get the highest value for your cable investment with our Cat 6 cables, each one manufactured using high-quality copper conductors. -
24-gauge wire for high-performance network connection
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet, using cables that include 24 AWG copper. -
50-micron gold connectors provide peak conductivity
Rely on our RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion. The N6PATCH75WH is backed by StarTech.com's lifetime warranty for guaranteed reliability.
- StarTech.com 75ft CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, White, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATCH75WH) - patch cable - 22.9 m - white
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Snagless
- Length
- 22.9 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Snagless
- Length
- 22.9 m
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL - up to 650 MHz
StarTech.com 100 ft White Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £31.89 |
StarTech.com 50 ft White Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £18.25 |
StarTech.com 75 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £25.96 |
StarTech.com 75 ft Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £25.96 |
StarTech.com 75ft Orange Cat6 Patch Cable | In Stock | £25.91 |
StarTech.com 75 ft Purple Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £25.96 |
StarTech.com 75 ft White Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £25.96 |
StarTech.com 75ft Yellow Cat6 Patch Cable | In Stock | £25.96 |
