Overheating hardware can be a problem in most server rooms. With StarTech.com's 70x70x15mm TX3 Dual Ball Bearing Fan Replacement Fan, you can avoid problems to workstations, and optimize system components for ideal performance.
Efficient cooling capability
Operating at a rotation speed of 3500 rpm, this fan circulates air to prevent overheating, ensuring all components remain at optimal temperatures. -
Durable design
Constructed from high-quality plastic, the fan is designed for durability, allowing it to withstand long hours of use without compromising performance. -
Quiet operation
With a sound emission of only 34 dB, users can enjoy a serene computing experience without the distraction of loud fan noise. -
Reliable ball bearing technology
The dual ball bearing mechanism provides improved efficiency and longer lifespan, making this fan a dependable choice for any computer system. -
Monitoring functionality
The fan features speed monitoring, allowing users to easily track performance and make adjustments to maintain optimal airflow.
 - StarTech.com 70x15mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector - 3 pin case Fan - TX3 Fan - 70mm Fan (FAN7X15TX3) - case fan
- Product Type
 - Case fan
 - Black
- Fan Diameter
 - 70 mm
- Fan Height
 - 15 mm
- Fan Bearing
 - Dual ball bearing
- Rotation Speed
 - 3500 rpm
- Air Flow
 - 28 cfm
- Product Material
 - Plastic
 - Fan speed monitoring
 - 2-year warranty
- Product Type
 - Case fan
- Product Material
 - Plastic
 - Black
Heatsink & Fan
- Fan Diameter
 - 70 mm
- Fan Height
 - 15 mm
- Fan Bearing
 - Dual ball bearing
- Rotation Speed
 - 3500 rpm
- Air Flow
 - 28 cfm
 - Limited warranty: - 2 years
- Sound Emission
 - 34 dB
