StarTech.com 70x15mm Replacement Ball Bearing Computer Case Fan with TX3 Connector
Quicklinx: 4MHJWS00 Mfr#: FAN7X15TX3
Type: Case Fan
£5.21 ex VAT
£6.25 inc VAT
Overheating hardware can be a problem in most server rooms. With StarTech.com's 70x70x15mm TX3 Dual Ball Bearing Fan Replacement Fan, you can avoid problems to workstations, and optimize system components for ideal performance.
  • Efficient cooling capability
    Operating at a rotation speed of 3500 rpm, this fan circulates air to prevent overheating, ensuring all components remain at optimal temperatures.
  • Durable design
    Constructed from high-quality plastic, the fan is designed for durability, allowing it to withstand long hours of use without compromising performance.
  • Quiet operation
    With a sound emission of only 34 dB, users can enjoy a serene computing experience without the distraction of loud fan noise.
  • Reliable ball bearing technology
    The dual ball bearing mechanism provides improved efficiency and longer lifespan, making this fan a dependable choice for any computer system.
  • Monitoring functionality
    The fan features speed monitoring, allowing users to easily track performance and make adjustments to maintain optimal airflow.
StarTech.com 70x15mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector - 3 pin case Fan - TX3 Fan - 70mm Fan (FAN7X15TX3) - case fan
Case fan
Fan Diameter
70 mm
Fan Height
15 mm
Fan Bearing
Dual ball bearing
Rotation Speed
3500 rpm
Air Flow
28 cfm
Product Material
Plastic
Fan speed monitoring
Case fan
Product Material
Plastic
Heatsink & Fan
Fan Diameter
70 mm
Fan Height
15 mm
Fan Bearing
Dual ball bearing
Rotation Speed
3500 rpm
Air Flow
28 cfm
Limited warranty: - 2 years
Sound Emission
34 dB
4MHJ StarTech.com 70x15mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.21
4MHJ StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan In Stock £5.42
Type: Case Fan
