StarTech.com 7-Pt Industrial USB 3.0 Hub w/ Ext. Power Supply
Quicklinx: FHHXWS00 Mfr#: HB30A7AME
Type: USB
Ports: 7
Data Transfer Rate: [N/A]
Managed: No
POE: No
18 In Stock
£118.82 ex VAT
£142.58 inc VAT
This TAA compliant 7-port industrial USB 3.0 hub gives you the scalability and power supply flexibility you need in harsh industrial environments, product, and repair labs, conference rooms or office workstations. With its rugged industrial-grade metal housing, it is designed to meet the advanced requirements of connecting a high number of devices in factories and office environments.
This industrial USB hub delivers reliable performance with a metal, heavy-duty housing. It supports wide-range 10-24V DC terminal block input, giving you the flexibility to power the hub as required, based on your own power input capabilities.
Perfect for factory environments, the rugged hub also supports a wide operating temperature range (0°C to 70°C) and offers surge and ESD protection to each USB port, which can help prevent damage to your connected devices.
Designed for a high volume of connections, this robust USB 3.0 hub offers 7 connection ports, for connecting more USB devices and peripherals.
The hub also supports USB battery charging specification 1.2, delivering up to 2.4A on any port to a maximum of 50W total, so you can charge your mobile devices faster than traditional USB ports allow.
With versatile installation options, you can install the hub where it's best suited for your environment. With built-in mounting brackets and included DIN mount rails, you can securely mount the USB 3.0 hub to most surfaces such as a wall, under a desk or rack.
It supports wide-range 10-24V DC terminal block input, giving you the flexibility to power the hub as required, based on your own power input capabilities. You have the option to power the industrial hub by connecting the hub directly to an outlet with the included external terminal block power adapter, for more convenient and flexible installation.
The rugged USB hub supports the full 5Gbps bandwidth of USB 3.0 and is backward compatible with previous USB devices. You can connect your legacy peripherals alongside your newer USB 3.0 devices without any disruptions.
  • Robust connectivity options
    Equipped with seven USB ports, this hub supports a variety of devices, allowing for efficient data transfer and connections.
  • Reliable power supply
    Includes a 65 W external power adapter, delivering stable power to connected devices, ensuring optimal performance.
  • Enhanced safety features
    Offers surge protection and ESD protection of 8 KV for contact discharge and 15 KV for air-gap discharge, safeguarding your equipment.
  • Versatile installation
    Designed for both DIN rail and wall mounting, this hub can be installed where it is most convenient for the workspace.
  • Wide compatibility
    Meets compliance standards like USB 1.1, USB 2.0, USB 3.0, and USB 3.2 Gen 1, making it compatible with a multitude of devices.
StarTech.com 7 Port USB Hub with Power Adapter, Surge Protection, Metal Industrial USB 3.0 Data Transfer Hub, Din Rail, Wall or Desk Mountable, High Speed USB 3.1/USB 3.2 Gen 1 5Gbps Hub - Windows/macOS/Linux (HB30A7AME) - hub - 7 ports - TAA Compliant
Hub - 7 ports
Subtype
USB
Ports
7 x USB 3.2 Gen 1
Surge protection, UFP, DFP, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge)
USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1
AC 120/230 V
13.3 cm x 61.5 cm x 36.3 cm
340 g
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
TAA Compliant
P/N: ITB20D3250
Hub - 7 ports
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
USB
Ports
7 x USB 3.2 Gen 1
X Genesys Logic GL3523
7 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 Type B
External power adapter
Power Provided
DC 20 V - 3.25 A
AC 120/230 V
65 Watt
Mounting screws, DIN-rail mounting kit
1 x USB host cable
MTBF
126,106 hours
FCC, REACH, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol)
TAA Compliant
13.3 cm
61.5 cm
36.3 cm
340 g
70 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
P/N: ITB20D3250
FHHX StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £9.84
FHHX StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.41
FHHX StarTech.com 15 ft USB 3.0 A to B Cable M/M In Stock £79.70
FHHX StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £40.15
FHHX StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £109.99
FHHX StarTech.com Industrial USB 2.0 Hub In Stock £43.13
FHHX StarTech.com Industrial USB 3.0 Hub In Stock £290.59
FHHX StarTech.com Industrial USB 5Gbps Hub In Stock £314.99
Type: USB
Ports: 7
Managed: No
POE: No
