Charge up to seven mobile devices simultaneously. This 7-port USB charging station lets you set up a multiport charge point for tablets, phones and other mobile devices.
This standalone USB charging strip offers five 1A and two 2A USB charging ports, so you can charge several mobile devices at the same time, without having to connect to multiple wall outlets or power bars.
The 7-port charging station supports Smart Charging capabilities, including USB Battery Charging Specification 1.2 and Apple and Samsung protocols, which ensures compatibility with a broad range of mobile devices, like the Apple iPhone and iPad, the Samsung Galaxy Tab, Android devices and more.
Create a dedicated USB charging station at your desk, so you can charge your mobile devices while you work. The charging station is also a great addition to your boardroom or lobby, providing a convenient way for mobile users to keep their devices powered.
With its integrated power button, you can turn all of the ports off while the charger isn't in use.
This compact charging strip takes up minimal space and features a rugged metal housing that can withstand the wear and tear of daily use. With the included wall-mount bracket, you can attach the charging strip to a surface such as a desktop or wall, for easy access to charge ports.
- StarTech.com 7 Port USB Charging Station with 5x 1A Ports and 2x 2A Ports charging strip - + AC power adapter - USB
- Product Type
- Charging strip + AC power adapter
- Designed For
- Tablet, mobile phone
- 4.5 cm x 11 cm x 2.4 cm
- 126 g
- Black
- Localisation
- Europe
- Output Connector Type
- Total 7: USB
- Voltage Required
- AC 100-240 V
- Voltage Provided
- DC 12 V
- Max Electric Current
- 5 A
- Power Device Details
- 5 x - 4 pin USB Type A - 1 A , 2 x - 4 pin USB Type A - 2 A
- 2-year warranty
- Product Type
- Designed For
- 4.5 cm
- 11 cm
- 2.4 cm
- 126 g
- Enclosure Colour
- Black
- Localisation
- Europe
- Voltage Required
- AC 100-240 V
- Input Connectors Qty
- 1
- 60 Watt
- Voltage Provided
- DC 12 V
- Output connectors
- Total 7: 4 pin USB Type A
- 5 A
- 5 x 4 pin USB Type A - 1 A , 2 x 4 pin USB Type A - 2 A
- AC Power Adapter Included
- LED indicator, wall mountable
- Material
- Aluminium
- Included Accessories
- 4 rubber feet, wall mounting bracket, mounting screw
- FCC, RoHS, REACH, USB Battery Charging Specification Rev. 1.2
- Shipping Width
- 23.5 cm
- Shipping Depth
- 9.8 cm
- Shipping Height
- 9.5 cm
- Shipping Weight
- 600 g
- Limited warranty - 2 years
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £37.42 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.44 |
StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £13.66 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £9.17 |
