StarTech.com 7-Port USB-C Hub, Self-Powered
Quicklinx: HDG2WS00 Mfr#: 10G5A2CS-USB-C-HUB
Type: USB Hub
Interface: USB 3.1 Type C, USB 3.2
Speed: 5Gbps
Ports: 7
Form Factor: External
Hurry, only 2 left in stock!
£101.47 ex VAT
£121.76 inc VAT
Add seven USB 3.2 Gen 2 (10Gbps) ports (5x USB-A, 2x USB-C) to a USB-C computer using this 7-Port USB-C Hub. The USB Hub is self-powered with an included power adapter. The USB Hub features Overcurrent Protection (OCP). OCP aids in preventing peripherals from overdrawing power, avoiding USB device dropouts, and the computers from shutting down unexpectedly. Support for Wake On USB enables USB communications, from devices connected to the hub, to take the computer out of standby or other power saving/sleep modes.
  • High Performance USB 3.2 Gen 2 (10Gbps) Hub
    The USB Hub shares 10Gbps from the USB host device, enabling high-speed data transfers for high-performance applications. The USB hub is backward compatible with previous USB versions, including USB 3.2 Gen 1 (5Gpbs), USB 2.0 (480Mbps), and USB 1.1 (12Mbps). It features five USB-A ports and two USB-C ports. This combination of ports enables support for a wide range of modern and legacy USB devices, such as external storage devices (e.g., thumb drives, HDDs/SSDs), HD Cameras (e.g., webcams), mice, keyboards, and USB headsets.
  • Power and Charge USB Devices
    The USB hub is self-powered, using the 65W power adapter. The hub features two USB BC 1.2 ports (1x USB-A, 1x USB-C), each providing 2.4A (12W) of power simultaneously, making it ideal to charge battery powered USB devices like smartphones, and tablets, while also providing a data connection. These ports will provide power with or without a host computer connected, with support for both CDP (Charging Downstream Port) & DCP (Dedicated Charging Port) applications. The hub features four USB-A, and one USB-C port that each provide the USB 3.2 standard of 0.9A (4.5W) of power. The included power adapter ensures that all ports will always provide specified power regardless of how many devices are connected.
  • USB-IF Certified Host Cable
    A high-quality USB-IF certified USB-C host cable is included. The cable features a screw-locking, connector to ensure a secure and reliable connection to the USB hub. The Thermoplastic Elastomer (TPE) cable jacket is softer and more flexible than PVC jacketed cables.
  • Plug-and-Play Installation
    The 7-Port USB Hub is OS independent supporting all operating systems, including Windows, macOS, ChromeOS, iPadOS and Android. Installation is automatic upon connection to a host computer. Mount the USB Hub to a wall, desk, or VESA mount, using StarTech.com hub mounts: SSPMSVESA or SSPMSUDWM.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The applicable software for this product is the USB Event Monitoring Utility. Use this utility to track and log any connected USB devices.
StarTech.com 7-Port USB-C Hub, 5x USB-A + 2x USB-C, Self-Powered w/ 65W Power Supply, USB 3.1 10Gbps Hub w/ BC1.2 Charging, Desktop/Laptop USB Hub with 3ft Locking USB-IF Certified Cable - USB Expansion Hub (10G5A2CS-USB-C-HUB) - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
5 x USB 3.2 Gen 2 + 2 x USB-C 3.2 Gen 2
Wall mountable, event log, self-powered mode, USB overcurrent detection and prevention, UASP, Fast Charging Port, wake on USB
USB 1.1, USB 2.0, USB 3.2 Gen 2, USB 3.2 Gen 1, USB-IF CERTIFIED
11.5 cm x 8 cm x 3 cm
287 g
Space grey
North America, United Kingdom, Europe
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X VIA VL822-Q7 / VL162
Status Indicators
Power, status
4 x USB 3.2 Gen 2 output Type A , 1 x USB 3.2 Gen 2 output Type A 15 Watt , 1 x USB-C input 15 Watt , 1 x USB-C input , 1 x USB-C output
External power adapter
Power Provided
DC 19 V - 3.42 A
65 Watt
Space grey
1 x USB cable - 1 m
Plug and Play, RoHS, REACH, Directive 2011/65/EU, Directive 2015/863/EU
11.5 cm
8 cm
3 cm
287 g
Shipping Width
25 cm
Shipping Depth
17 cm
Shipping Height
9.5 cm
Shipping Weight
1.2 kg
50 °C
0 - 95% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
HDG2 StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.27
HDG2 StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA In Stock £14.31
HDG2 StarTech.com 10-Port USB-C Hub Self-Powered In Stock £109.54
Type: USB Hub
Interface: USB 3.2
Speed: 5Gbps
Ports: 7
