Turn a USB Type-C port on your laptop into five USB Type-A ports (5Gbps) and two USB Type-C ports. This USB-C hub turns your laptop or desktop USB Type-C or Thunderbolt 3 port into four standard USB-A ports, one USB-A fast-charge port, and two USB-C ports. You can also extend the range of your USB devices by using this hub as a mid-point repeater.
The 7-port USB hub provides convenient port access. The extended length of the supplied cable offers the flexibility to position your hub and USB devices as needed, in order to create a comfortable, space-efficient work area. The ports are sufficiently spaced to plug or unplug your USB devices without needing to disconnect other devices from neighboring ports.
With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or avoid the hassle of swapping connected devices on your port-limited laptop.
The hub lets you extend the life of your current USB 3.0 devices while also taking advantage of newer USB-C devices.
With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it's charging. The USB-A charge port supports USB Battery Charging Specification 1.2.
- StarTech.com 7 Port USB C Hub with Fast Charge Port, USB-C to 5x USB-A 2x USB-C USB 3.0 (USB 3.1/3.2 Gen 1 SuperSpeed 5Gbps), Self Powered Type-C Hub w/ Power Adapter, Desktop/Laptop Hub - Windows/macOS/Linux (HB30C5A2CSC) - hub - 7 ports
- Hub - 7 ports
- Subtype
- USB
- Ports
- 5 x SuperSpeed USB 3.0 + 2 x USB-C
- Plastic housing, Fast Charging Port
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 120/230 V 1 A
- 14.9 cm x 6.5 cm x 2.4 cm
- 250 g
- Black, silver
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- 2-year warranty
- Hub - 7 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Processor
- X VIA VL813
- Status Indicators
- Active
- 4 x USB 3.0 Type A , 1 x USB 3.0 Type A Fast-Charge , 2 x USB-C
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 4 A
- Voltage Required
- AC 120/230 V
- Electric Current Required
- 1 A
- 48 Watt
- Black, silver
- Cables Included
- 1 x USB cable - 1 m
- FCC, RoHS, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol)
- Localisation
- 14.9 cm
- 6.5 cm
- 2.4 cm
- 250 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black | In Stock | £19.33 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £20.75 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £30.59 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.29 |
StarTech.com 4 Port USB 3.0 C Hub - C to A | In Stock | £27.64 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £14.59 |
StarTech.com 2m 6ft USB 3.0 C to B Cable | In Stock | £13.23 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
StarTech.com 1m USB A to C Cable - USB 3.0 | In Stock | £8.23 |
StarTech.com 4-Port USB-C Hub, 100W PD | In Stock | £38.06 |
StarTech.com Portable 4pt USB-C Hub, 10Gbps | In Stock | £31.91 |
