StarTech.com 7 Port PCIe USB 3.0 Card
Quicklinx: B7YKWS00 Mfr#: PEXUSB3S7
Type: USB adapter
Compatibility: PC, Unix
Interface: PCI Express 2.0 x1
45 In Stock
£56.73 ex VAT
£68.07 inc VAT
Get the scalability you need by adding 7 USB 3.0 ports with SATA power to your computer. Handle your workload more efficiently. This USB 3.0 card expands your computer's capabilities by giving you seven extra USB 3.0 ports. It's engineered with an innovative stacked port layout to fit easily into both low-profile and standard desktop computers.
More ports means you can add USB devices as you need them. This robust USB 3.0 card gives you seven USB 3.0 ports - six external and one internal - so you can plug in your tablets, smartphones, external hard drives, CD/DVD drives, printer and other devices at the same time. With so many extra ports, you can leave your devices plugged in, so they're ready to use when you need them. It's also economical - by being able to connect so many devices, you save the cost of extra hubs or cards.
The internal USB 3.0 port lets you connect a USB device inside your computer for added convenience and security.
This versatile USB 3.0 card features a dual-profile design with a stacked port layout. The innovative port configuration allows a high number of external ports in a compact design, allowing it to fit both low-profile and full desktop computer systems. A bracket is included for installation into low-profile computers.
You'll be up and running in no time. The card automatically installs in Windows 8, and 8.1, with native operating system support. It's also backward compatible with USB 2.0 and 1.x devices to help you get the most out of your existing peripherals.
This high-performance SuperSpeed USB 3.0 card supports data transfer rates up to 5 Gbps and is enhanced with UASP support, which can perform ~70% faster read speed and 40% faster write speed over traditional USB 3.0, when paired with a UASP-enabled enclosure.
The rugged build quality of the card delivers long-lasting performance, and gives you peace of mind when connecting multiple devices.
UASP (USB Attached SCSI Protocol) is supported in Windows 8, 8.1, Server 2012 and Linux kernel 2.6.37 or later. Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 7 Port PCI Express USB 3.0 Card - Standard & Low-Profile - SATA Power - UASP Support - 1 Internal & 6 External USB 3.0 Ports (PEXUSB3S7) - USB adapter - PCIe 2.0
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x1
PCI Specification Revision
PCIe 2.0
12 cm x 10.5 cm x 1.5 cm
72 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 2.6.31 - 4.11.x LTS versions only
P/N: ST1030USBM, ST7300USBME
USB adapter
Plug-in card
PCI Express 2.0 x1
PCIe 2.0
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
UASP
6 x USB 3.0 - 9 pin USB Type A (external) , 1 x USB 3.0 - 9 pin USB header (internal) , 1 - 15 pin Serial ATA power
Low-profile bracket
Software Included
Drivers & Utilities
12 cm
10.5 cm
1.5 cm
72 g
5 °C
50 °C
20 - 80%
B7YK StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
B7YK StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £84.93
B7YK StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
B7YK StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £22.56
B7YK StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power In Stock £19.39
B7YK StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £39.78
B7YK StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
B7YK StarTech.com 7 Port PCIe USB 3.0 Card In Stock £56.73
B7YK StarTech.com 4 Port PCIe USB 3.0 Card In Stock £27.19
B7YK StarTech.com 4 Port PCIe USB 3.0 Card In Stock £23.79
B7YK StarTech.com 3 Port PCIe USB 3.0 Card + GbE In Stock £42.00
B7YK StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £38.05
B7YK StarTech.com 2-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x2 In Stock £24.39
B7YK StarTech.com 4-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x4 In Stock £87.44
B7YK StarTech.com 1-Port USB 3.2 Gen 2x2 PCIe Card - USB-C SuperSpeed 20Gbps PCI Express 3.0 x4 In Stock £40.64
Type: USB adapter
Compatibility: PC
Compatibility: Unix
