StarTech.com 7 Port Black USB 2.0 Hub
Quicklinx: 5JSBWS00 Mfr#: ST7202USBGB
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 7
Form Factor: External
  • Hi-Speed USB
More than 50 in stock
£18.09 ex VAT
£21.70 inc VAT
This 7 Port USB 2.0 Hub connects to one USB 2.0 port on a Mac or PC computer, adding seven USB 2.0 ports - allowing you to maximize the number of high speed USB peripherals connected to your computer. The hub supports cascaded installation with other USB 2.0 hubs, supporting up to 127 USB 2.0 device connections - a scalable solution for connecting multiple USB devices to a single host computer.
The 7 port hub includes a power adapter, but can be powered through USB bus connection to the host computer - allowing you to install the hub as needed without worrying about the availability of a power outlet.
The USB 2.0 hub offers an attractive black casing that suits any operating environment and includes a 3ft USB 2.0 A/B male-male cable, for the connection between the hub and the host computer.
StarTech.com 7 Port USB 2.0 Hub – Portable and Compact – Bus Powered USB 2.0 Extender – USB Multiport Expander (ST7202USB) - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x USB 2.0
4.8 cm x 8 cm x 2.5 cm
272 g
Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
United Kingdom
1-year warranty
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
7 x USB 2.0
Status Indicators
7 x USB 2.0 Type A , 1 x USB 2.0 Type B
External power adapter
1 x USB cable - 91 cm
UL, FCC, RoHS
United Kingdom
Software Included
Drivers & Utilities
4.8 cm
8 cm
2.5 cm
272 g
Limited warranty - 1 year
5JSB StarTech.com 6ft High Speed USB 2.0 Cable In Stock £3.42
5JSB StarTech.com 7 Port Black USB 2.0 Hub In Stock £18.09
5JSB StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.42
5JSB StarTech.com DC Power Adapter - 5V, 2A In Stock £9.56
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 7
Price Range Ex VAT: 0 - 50
