This 7 Port USB 2.0 Hub connects to one USB 2.0 port on a Mac or PC computer, adding seven USB 2.0 ports - allowing you to maximize the number of high speed USB peripherals connected to your computer. The hub supports cascaded installation with other USB 2.0 hubs, supporting up to 127 USB 2.0 device connections - a scalable solution for connecting multiple USB devices to a single host computer.
The 7 port hub includes a power adapter, but can be powered through USB bus connection to the host computer - allowing you to install the hub as needed without worrying about the availability of a power outlet.
The USB 2.0 hub offers an attractive black casing that suits any operating environment and includes a 3ft USB 2.0 A/B male-male cable, for the connection between the hub and the host computer.
Compact and portable design
The compact form factor of the StarTech.com USB hub makes it easy to carry and fit into any workspace, providing convenience for users on the go. -
Seven USB 2.0 ports
Equipped with seven USB 2.0 ports, this hub allows multiple devices to connect simultaneously, enhancing productivity without the need for constant swapping. -
External power adapter
The included external power adapter ensures stable performance and sufficient power for all connected devices, allowing for efficient charging and data transfer. -
Status indicator
The built-in status indicator provides visual cues on power status, allowing users to easily check the operational state of the hub and connected devices. -
Mac compatibility
This USB hub is compatible with Mac systems, ensuring users can integrate it into their existing setups without any hassle.
- StarTech.com 7 Port USB 2.0 Hub – Portable and Compact – Bus Powered USB 2.0 Extender – USB Multiport Expander (ST7202USB) - hub - 7 ports
- Hub - 7 ports
- Subtype
- USB
- Ports
- 7 x USB 2.0
- 4.8 cm x 8 cm x 2.5 cm
- 272 g
- Black
- System Requirements
- Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
- Localisation
- United Kingdom
- 1-year warranty
- Hub - 7 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 7 x USB 2.0
- Status Indicators
- Power
- 7 x USB 2.0 Type A , 1 x USB 2.0 Type B
- Power Device
- External power adapter
- Black
- Cables Included
- 1 x USB cable - 91 cm
- UL, FCC, RoHS
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 4.8 cm
- 8 cm
- 2.5 cm
- 272 g
- Limited warranty - 1 year
StarTech.com 7 Port Black USB 2.0 Hub | In Stock | £23.67 |
StarTech.com DC Power Adapter - 5V, 2A | In Stock | £9.67 |
