StarTech.com 7.5m CAT6a Ethernet Cable LSZH - White
Quicklinx: H15RWS00 Mfr#: NLWH-750-CAT6A-PATCH
Length: 7.5m
Colour: White
£29.80 ex VAT
£35.76 inc VAT
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
Available in a variety of lengths and colors, the shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
  • High-speed performance
    This CAT 6a Ethernet cable supports data rates of up to 10 Gbps, ensuring smooth and rapid data transmission for demanding applications.
  • Durable construction
    The cable features molded connectors and strain relief to withstand daily wear and tear, ensuring reliable performance over time.
  • Effective shielding
    With S/FTP technology and foil shielding, the cable minimizes EMI/RFI interference, providing stable and quality connections.
  • Safety compliant
    Made of Low Smoke Zero Halogen material, this cable is compliant with safety standards, reducing toxicity and smoke in case of fire.
  • Maximized power delivery
    Supports up to 100 W input power, making it suitable for powering network devices alongside high-speed data transmission.
StarTech.com 7.5m CAT6a Ethernet Cable - White - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 7.5 m - white
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
7.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7.5 m
257.5 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
20 cm
Shipping Depth
18 cm
Shipping Height
4 cm
Shipping Weight
266.2 g
Length: 7.5m
Colour: White
