CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 7.5m - Blue - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
Reliable performance
This patch cable is built to support high-speed data transfers with a maximum input power of 100 W, making it suitable for power over Ethernet applications. -
Durable construction
The cable is made with a Low Smoke Zero Halogen jacket that protects the internal wires and reduces harmful emissions in case of fire. -
Efficient shielding
Equipped with foil shielding, this cable minimizes interference from EMI/RFI, ensuring a stable and clear connection for your network needs. -
Snagless design
The molded and snagless RJ-45 connectors prevent the cable from snagging during installation, reducing the risk of damage. -
Compliance assurance
Meets various compliance standards, including ANSI/TIA-568.2-D and PoE++, ensuring it is safe and reliable for various installations.
- StarTech.com 7.5m CAT6a Ethernet Cable - Blue - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 7.5 m - blue
- Patch cable - CAT 6a - IEEE 802.3bt
- Technology
- S/FTP
- Shielding Material
- Foil
- Wires per Cable
- 8 wires
- Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
- Length
- 7.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Foil
- Jacket Material
- American Wire Gauge (AWG)
- 27
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 7.5 m
- 257.5 g
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
- Shipping Width
- 20 cm
- Shipping Depth
- 18 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 266.2 g
