StarTech.com 7.5m CAT6a Ethernet Cable LSZH - Blue
Quicklinx: H15FWS00 Mfr#: NLBL-750-CAT6A-PATCH
Length: 7.5m
Colour: Blue
£29.80 ex VAT
£35.76 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 7.5m - Blue - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Reliable performance
    This patch cable is built to support high-speed data transfers with a maximum input power of 100 W, making it suitable for power over Ethernet applications.
  • Durable construction
    The cable is made with a Low Smoke Zero Halogen jacket that protects the internal wires and reduces harmful emissions in case of fire.
  • Efficient shielding
    Equipped with foil shielding, this cable minimizes interference from EMI/RFI, ensuring a stable and clear connection for your network needs.
  • Snagless design
    The molded and snagless RJ-45 connectors prevent the cable from snagging during installation, reducing the risk of damage.
  • Compliance assurance
    Meets various compliance standards, including ANSI/TIA-568.2-D and PoE++, ensuring it is safe and reliable for various installations.
StarTech.com 7.5m CAT6a Ethernet Cable - Blue - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 7.5 m - blue
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
7.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7.5 m
257.5 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
20 cm
Shipping Depth
18 cm
Shipping Height
4 cm
Shipping Weight
266.2 g
Length: 7.5m
Colour: Blue
