StarTech.com 7.5m CAT6a Ethernet Cable LSZH - Aqua
Quicklinx: H14SWS00 Mfr#: NLAQ-750-CAT6A-PATCH
Length: 7.5m
Colour: Aqua
£28.47 ex VAT
£34.16 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 7.5m - Turquoise - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Performance
    The cable supports data transmission speeds of up to 10 Gbps, making it suitable for high-bandwidth applications. Its tested frequency reaches up to 500 MHz, ensuring efficient data transfer.
  • Safety-focused design
    Constructed with Low Smoke Zero Halogen (LSZH) materials, this cable reduces harmful emissions during fire, providing an added layer of safety in sensitive environments.
  • Reliable connectivity
    Equipped with RJ-45 connectors on both ends, this cable ensures a secure connection. The molded, snagless design protects the connectors from damage while facilitating easy installation.
  • Durable construction
    The use of copper conductors along with foil shielding ensures EMI/RFI protection and minimizes Near-End Crosstalk (NEXT), enhancing overall performance.
  • Versatile use
    Compliant with multiple standards including IEEE 802.3bt and PoE++, this cable is ideal for various networking applications, suitable for both home and commercial use.
StarTech.com 7.5m CAT6a Ethernet Cable - Aqua - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 7.5 m - aqua
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
7.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Aqua
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7.5 m
257.5 g
Aqua
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
20 cm
Shipping Depth
18 cm
Shipping Height
4 cm
Shipping Weight
266.2 g
Length: 7.5m
Colour: Aqua
