StarTech.com 7.5 m CAT6a Cable - Black- CAT6a STP Cable - Snagless RJ45
Quicklinx: FMHTWS00 Mfr#: 6ASPAT750CMBK
Length: 7.5m
Colour: Black
£27.78 ex VAT
£33.33 inc VAT
100% COPPER WIRING: The CAT6a Ethernet cables are built with 100% copper wiring to prevent weak power delivery and equipment damage, compared to copper-clad aluminum wire cables
QUALITY PERFORMANCE: Built for high performance, each CAT6a patch cable features 26 AWG copper wiring and is tested to comply with ANSI/TIA 568 C.2 CAT6a requirements
EASY INSTALLATION: The 7.5 m network cords feature snagless connectors and molded boots to protect the RJ-45 clips from cable damage during installations and to ensure a secure network connection
26 AWG WIRE: All shielded CAT6a STP cables are built with 26 AWG wiring to ensure peak performance for your demanding Ethernet applications
StarTech.com 7.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Black, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT750CMBK) - patch cable - 7.5 m - black
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, RFI/EMI shielding
Length
7.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7.5 m
290 g
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
Length: 7.5m
Colour: Black
