StarTech.com 7.5 m CAT6 Cable - White CAT6 Patch Cord - Snagless RJ45
Quicklinx: FNL7WS00 Mfr#: N6PATC750CMWH
Length: 7.5m
Colour: White
24 In Stock
£12.49 ex VAT
£14.98 inc VAT
7.5 m CAT6 Patch Cable , Snagless , 100% Copper Wire White ETL Verified. This CAT6 cable meets all Category 6 cable specifications, to deliver a reliable Gigabit network connection.
Protect Your Equipment
This CAT6 patch cable is built using 100% copper wire and are tested to comply with ANSI/TIA 568 C.2 Category 6 requirements. We don't use copper-clad aluminum (CCA) wire, which is subject to problems like weak power delivery, heat buildup, equipment damage and possibly fire.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
High-Quality Construction
The CAT6 cable is manufactured using high-quality copper conductors and carefully constructed and tested to keep Near-End Crosstalk (NEXT) well within acceptable limits. The patch cable is constructed with 24 AWG copper wire, to ensure peak performance for demanding Ethernet applications such as Power-over-Ethernet and 4K or 1080p video streaming.
Easily Install Your Network Cables
For trouble-free cable runs, this durable cable feature snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The CAT6 Ethernet cable also features molded boots which offer strain relief by stopping the RJ45 connectors from bending at sharp angles. This reduces the risk of cable damage, which could decrease network connectivity and performance.
N6PATC750CMWH is backed by a StarTech.com lifetime warranty for guaranteed reliability.
  • 100% copper for outstanding value
    Get high value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
  • 24-gauge wire for high-performance network connections
  • 50-micron gold connectors provide peak conductivity
    Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 7.5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, White, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC750CMWH) - patch cable - 7.5 m - white
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Snagless, minimised Near-End Crosstalk (NEXT)
Length
7.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7.5 m
1.16 cm
0.82 cm
320 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, REACH, ANSI/TIA-568-C.2, CMG, TIA/EIA-568-B.1-2001 - up to 650 MHz
Shipping Width
36 cm
Shipping Depth
20 cm
Shipping Height
4 cm
Shipping Weight
332 g
Length: 7.5m
Colour: White
