Turn your laptop or desktop computer into a 7.1-channel home theater-ready sound system. This versatile External USB Sound Card/Audio Adapter offers a high quality solution for upgrading desktop or laptop sound.
Providing a robust USB audio experience, the USB sound card connects to a host computer through a single USB 2.0 connection, to deliver impressive external audio capability that can instantly be swapped between systems, without having to open the computer case for installation.
Supporting analog and digital audio for 2 to 7.1 channel audio applications, the external USB sound card provides a cost-saving upgrade from built-in/on-board sound that turns desktop/laptop sound into a home theater-ready audio solution.
The external USB sound card features easy-to-use volume control and two external microphone inputs - a convenient solution for any audio application requiring high quality sound with multi-input capability with support for 44.1 KHz and 48 KHz sampling rates for both playback and recording.
A more than suitable solution for home theater, gaming or multi-media presentations, the External USB Sound Card is easy to install with plug and play support in Windows XP and Windows Vista operating systems.
The audio adapter's SPDIF optical pass-through port supports two-channel audio, this port does not support 5.1 or 7.1 audio.
Immersive audio experience
The 7.1 channel surround sound provides enhanced audio, allowing users to enjoy a full spectrum of sound while gaming, watching movies, or enjoying music. -
User-friendly controls
The sound card features convenient volume control and mute button, making it easy to adjust audio during use. -
Flexible connectivity options
With multiple input and output ports, including options for microphones, headphones, and multiple speaker configurations, this sound card accommodates various audio setups. -
Reliable operating conditions
Designed to perform optimally from 0°C to 55°C and within 20% to 80% humidity, ensuring consistent performance in diverse environments.
- StarTech.com 7.1 USB Sound Card - External Sound Card for Laptop with SPDIF Digital Audio - Sound Card for PC - Silver (ICUSBAUDIO7D) - sound card
- Sound card
- Enclosure Type
- External
- Interface Type
- USB 2.0
- 10 cm x 6 cm x 2.5 cm
- 100 g
- Silver
- Sound Output Mode
- 7.1 channel surround
- Sample Rate
- 48 kHz (max)
- Hardware Controls And Indicators
- Volume control, mute button
- System Requirements
- Microsoft Windows 2000 Server, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: MU15MMS, MU6MMS
- Sound card
- Form Factor
- External
- Interface Type
- USB 2.0
- 10 cm
- 6 cm
- 2.5 cm
- 100 g
- Enclosure Colour
- Silver
Audio Output
- Sound Output Mode
- Sample Rate
- 48 kHz (max)
- 1 x headphones - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x speakers (side surround) - mini-phone stereo 3.5 mm , 1 x speakers (centre/subwoofer) - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x speakers (back surround) - mini-phone stereo 3.5 mm , 1 x SPDIF output - TOSLINK , 1 x SPDIF input - TOSLINK , 2 x microphone - mini-phone stereo 3.5 mm
- Plug and Play, FCC, RoHS
- Software
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years , Technical support - lifetime
- 0 °C
- 55 °C
- 20 - 80%
- Designed For
StarTech.com USB Stereo Audio Adapter External Sound Card | In Stock | £14.39 |
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £18.58 |
StarTech.com 7.1 USB Audio Adapter External Sound Card with SPDIF Digital Audio | In Stock | £29.77 |
StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio | In Stock | £23.31 |
StarTech.com 7.1 Channel PCIe Sound Card | In Stock | £41.86 |
StarTech.com USB-C Audio Adapter to 3.5mm | In Stock | £13.26 |
