Add digital optical surround sound to your computer through PCIe. With this 7.1-channel PCIe sound card, you can create a high-quality home theater sound system. It offers SPDIF input and output ports which deliver crystal-clear digital optical audio, for the ultimate listening experience.
The versatile sound card can be used with a variety of audio devices. And with SPDIF digital optical or 3.5mm analog output, you don't need to worry about the connection types on your devices. You can output digital audio to your optical receiver or DAC, or analog audio to your sound system.
With up to 24-bit and 192KHz playback and recording, this 7.1 surround sound adapter card delivers high-definition audio for superb sound quality.
Unlike typical sound cards, this card is designed to fit in low-profile computers, making it ideal for home theater personal computers (HTPC). It spans the multiple ports across a main card plus an innovative separate header bracket. The card is configured with standard profile brackets and includes low-profile (half-height) brackets.
The 7.1 channel surround sound card is easy to install. It's perfect for anyone looking for a simple solution to upgrade their listening experience, such as music enthusiasts or mixing professionals.
For added scalability, you can quickly connect a microphone or other recording devices to your computer through two 3.5mm stereo or SPDIF digital audio input jacks.
- StarTech.com 7.1 Channel Sound Card - PCI Express - 24-bit - 192KHz - SPDIF Digital Optical and 3.5mm Analog Audio (PEXSOUND7CH) - sound card
- Sound card - low profile
- Enclosure Type
- Internal
- Interface Type
- PCI Express x1
- 1.8 cm x 11.4 cm x 12 cm
- 105 g
- Signal Processor
- CM8828
- Sound Output Mode
- 7.1 channel surround
- Sample Rate
- 192 kHz (max)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, MU15MMS, MU6MMS, TB31PCIEX16
- Form Factor
- Internal
- Interface Type
- PCI Express x1
- 1.8 cm
- 11.4 cm
- 12 cm
- 105 g
Processor / Memory
- Signal Processor
- CM8828
Audio Output
- Sound Output Mode
- Sample Rate
- 192 kHz (max)
- Audio Modes
- Playback: 24-bit 192 kHz 7.1 - 92 dB , Record: 24-bit 192 kHz
- 2 x audio line-in - TOSLINK , 6 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 9 pin IDC , 2 - 10 PIN IDC
- Included Accessories
- 2 x low-profile brackets
- FCC, RoHS
- OS Required
- Limited warranty - 2 years
- 20 °C
- 70 °C
- 10 - 90%
- Designed For
StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F | In Stock | £4.91 |
StarTech.com 12 ft PC Speaker Extension Audio Cable | In Stock | £4.98 |
StarTech.com 7.1 USB Audio Adapter External Sound Card with SPDIF Digital Audio | In Stock | £29.57 |
StarTech.com Virtual 7.1 USB Stereo Audio Adapter External Sound Card | In Stock | £16.61 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.83 |
StarTech.com 3.5mm 4 Position to 2x 3 Position 3.5mm Headset Splitter Adapter - F/M | In Stock | £7.66 |
StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female | In Stock | £4.21 |
StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable | In Stock | £5.24 |
StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio | In Stock | £24.36 |
StarTech.com 3m White Slim 3.5mm Stereo Audio Cable - Male to Male | In Stock | £8.62 |
