StarTech.com 7.1 Channel PCIe Sound Card
Quicklinx: BBD8WS00 Mfr#: PEXSOUND7CH
Interface: PCI Express x1
Sound Output Mode: 7.1 channel surround
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£41.21 ex VAT
£49.45 inc VAT
Add digital optical surround sound to your computer through PCIe. With this 7.1-channel PCIe sound card, you can create a high-quality home theater sound system. It offers SPDIF input and output ports which deliver crystal-clear digital optical audio, for the ultimate listening experience.
The versatile sound card can be used with a variety of audio devices. And with SPDIF digital optical or 3.5mm analog output, you don't need to worry about the connection types on your devices. You can output digital audio to your optical receiver or DAC, or analog audio to your sound system.
With up to 24-bit and 192KHz playback and recording, this 7.1 surround sound adapter card delivers high-definition audio for superb sound quality.
Unlike typical sound cards, this card is designed to fit in low-profile computers, making it ideal for home theater personal computers (HTPC). It spans the multiple ports across a main card plus an innovative separate header bracket. The card is configured with standard profile brackets and includes low-profile (half-height) brackets.
The 7.1 channel surround sound card is easy to install. It's perfect for anyone looking for a simple solution to upgrade their listening experience, such as music enthusiasts or mixing professionals.
For added scalability, you can quickly connect a microphone or other recording devices to your computer through two 3.5mm stereo or SPDIF digital audio input jacks.
StarTech.com 7.1 Channel Sound Card - PCI Express - 24-bit - 192KHz - SPDIF Digital Optical and 3.5mm Analog Audio (PEXSOUND7CH) - sound card
Sound card - low profile
Enclosure Type
Internal
Interface Type
PCI Express x1
1.8 cm x 11.4 cm x 12 cm
105 g
Signal Processor
CM8828
Sound Output Mode
Sample Rate
192 kHz (max)
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, MU15MMS, MU6MMS, TB31PCIEX16
Internal
Interface Type
PCI Express x1
1.8 cm
11.4 cm
12 cm
105 g
Processor / Memory
Signal Processor
CM8828
Audio Output
Sound Output Mode
Sample Rate
192 kHz (max)
Audio Modes
Playback: 24-bit 192 kHz 7.1 - 92 dB , Record: 24-bit 192 kHz
2 x audio line-in - TOSLINK , 6 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 9 pin IDC , 2 - 10 PIN IDC
2 x low-profile brackets
FCC, RoHS
20 °C
70 °C
10 - 90%
BBD8 StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £4.99
BBD8 StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £5.05
BBD8 StarTech.com 7.1 USB Audio Adapter External Sound Card with SPDIF Digital Audio In Stock £29.31
BBD8 StarTech.com Virtual 7.1 USB Stereo Audio Adapter External Sound Card In Stock £15.42
BBD8 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.85
BBD8 StarTech.com 3.5mm 4 Position to 2x 3 Position 3.5mm Headset Splitter Adapter - F/M In Stock £7.78
BBD8 StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female In Stock £4.25
BBD8 StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable In Stock £5.33
BBD8 StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio In Stock £23.31
BBD8 StarTech.com 3m White Slim 3.5mm Stereo Audio Cable - Male to Male In Stock £5.56
