StarTech.com 6U Wall Mount Rack Bracket
Quicklinx: CPBTWS00 Mfr#: RK619WALLV
Product Type: Wall mount bracket
Hurry, only 3 left in stock!
£73.86 ex VAT
£88.63 inc VAT
Mount server, network or telecommunications devices vertically with this 6U wall-mountable rack. This wall-mount bracket provides 6U of storage space to vertically mount your equipment on the wall. The 6U wall-mount rack is EIA-310-D compliant to ensure compatibility with any 19" rack-mount equipment, such as your power strips, telecommunication, network and A/V devices.
The 6U rack optimizes your working space by mounting equipment to your wall instead of taking up desk space or other surface area. It's perfect for your SoHo (small office, home office) environment, server room or any other location where available space is limited.
The wall rack is constructed of solid steel to ensure a sturdy and safe mounting solution for your expensive, mission-critical equipment. Also, because the wall mounting holes are positioned 16"apart, it exactly matches standard drywall construction framework to ensure simple and secure wall-stud anchoring. Cage nuts and screws are also included with the wall-mount bracket, to save you the hassle of sourcing separate mounting hardware.
To provide a suitable mounting solution for virtually any surface such as your wall, ceiling or desk, the 6U bracket features separate mounting patterns for both ceilings and walls. This means that you can mount the bracket vertically to your wall or horizontally to your ceiling or under your desk.
If you're looking for a mountable storage solution with fewer rack units, StarTech.com also offers a 1U wall-mount bracket, a 2U wall-mount bracket, a 3U wall-mount bracket and a 4U wall-mount bracket.
  • Save space by mounting your equipment to the wall or other surface
  • Ensure a secure and hassle-free installation
  • Customize your workspace with versatile installation options
    To provide a suitable mounting solution for virtually any surface such as your wall, ceiling or desk, the 6U bracket features separate mounting patterns for both ceilings and walls. This means that you can mount the bracket vertically to your wall or horizontally to your ceiling or under your desk. If you're looking for a mountable storage solution with fewer rack units, StarTech.com also offers a 1U wall-mount bracket, a 2U wall-mount bracket, a 3U wall-mount bracket and a 4U wall-mount bracket. The RK619WALLV is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 6U Wall Mount Patch Panel Bracket - 19 in - Steel - Vertical Mounting Bracket for Networking and Data Equipment (RK619WALLV) - wall mount bracket - 6U
Wall mount bracket
Rack Size
19"
Height (Rack Units)
6U
Product Material
Steel
50.4 cm x 19.35 cm x 15.1 cm
Wall mount bracket
Product Material
Steel
Rack Size
19"
Height (Rack Units)
6U
50.4 cm
19.35 cm
15.1 cm
Inner Dimensions
45 cm
Weight Limit
56.7 kg
Mounting Kit
Included
Limited warranty: - lifetime
CPBT StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £19.93
CPBT StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £40.86
CPBT StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £39.32
CPBT StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £53.59
CPBT StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.74
CPBT StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £35.39
CPBT StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £16.28
CPBT StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £32.84
CPBT StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £62.33
CPBT StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £65.84
CPBT StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £35.51
CPBT StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.16
CPBT StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £65.84
CPBT StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £32.13
CPBT StarTech.com 50 Pkg M6 Cage Nuts In Stock £22.74
CPBT StarTech.com 100 Pkg M5 Cage Nuts In Stock £34.53
CPBT StarTech.com 50 Pkg M5 Cage Nuts In Stock £17.25
CPBT StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £62.33
CPBT StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £32.84
CPBT StarTech.com 50 Pkg M5 Mounting Screws In Stock £18.34
CPBT StarTech.com 100 Pkg M5 Mounting Screws In Stock £34.53
CPBT StarTech.com 50 Pkg M6 Mounting Screws In Stock £19.35
CPBT StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.55
CPBT StarTech.com 100 Pkg M6 Cage Nuts In Stock £30.84
CPBT Startech.com 100 Pkg M6 Mounting Screws In Stock £28.59
CPBT StarTech.com 19in Cable Management Panel In Stock £24.78
CPBT StarTech.com M6 Mounting Screws 50Pack In Stock £17.54
