StarTech.com 6U Wall-mount Rack - Open Frame - 2 Post - 18 in. Deep - 175lb. Weight Capacity
Quicklinx: FSHYWS00 Mfr#: RK619WALLO
Depth (mm): 45.7cm
Width (mm): 55.5cm
Hurry, only 2 left in stock!
£110.76 ex VAT
£132.91 inc VAT
The wall mount open-frame rack is perfect for smaller spaces. It's easy to assemble and features mounting holes that are spaced 16" apart, making it suitable for mounting on almost any wall, based on common wall-frame stud spacing.
  • Easy, Hassle-Free Installation
    The wall mount open frame rack is 18 in. (45.7 cm) deep, so it's perfect for smaller spaces. It ships fully assembled and features mounting holes that are spaced 16 in. apart, making it suitable for mounting on almost any wall, based on common wall-frame stud spacing.
  • Free Up Space
    You can mount the wall mount open frame rack where space is limited, such as on a server room wall, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access.
  • Keep Your Equipment Cool and Accessible
    By having an open frame, the small wall mount network rack provides passive cooling to equipment. Additionally, the open frame provides easy access and configurability to your equipment, allowing you to maximize productivity.
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The RK619WALLO is backed by a StarTech.com a lifetime warranty and free lifetime technical support.
StarTech.com 6U 19" Wall Mount Network Rack 19" Deep 2 Post Open Frame for Server Room Data/AV/IT/Communication/Computer Equipment/Patch Panel with Cage Nuts/Screws Hook/Loop, Cisco 2960 - 19 Inch Wallmount Rack (RK619WALLO) - rack - 6U
Rack
Rack Type
Open frame - 2-post
Placing / Mounting
Wall mountable
Package Content
24 M6 cage nuts, 24 M6 screws, 10 ft black hook-and-loop roll
Rack Size
19"
Height (Rack Units)
6U
Product Material
Steel
55.5 cm x 45.7 cm x 40.7 cm
10.5 kg
Rack
Rack Type
Open frame
Rack Post Qty
2-post
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Rack Size
19"
Height (Rack Units)
6U
55.5 cm
45.7 cm
40.7 cm
10.5 kg
62 cm x 52.5 cm x 47.5 cm / 10.7 kg
Weight Limit
80 kg
EIA-310-C, RoHS, REACH, ECA-310-E
Limited warranty: - lifetime
FSHY StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £8.29
FSHY StarTech.com 19in Cable Management Panel In Stock £23.58
Depth (mm): 45.7cm
Width (mm): 55.5cm
