Vertically wall-mount your server or networking equipment in this 6U network cabinet. This 6U vertical server cabinet offers a space-saving way to keep your network and server equipment secure. With its 30 in. depth and a weight capacity of up to 200 lb. (90.7 kg), the server rack/cabinet is designed to fit your needs. It also features an additional 2U mounting bracket positioned toward the top of the enclosure that you can use to mount patch cables or other shallow rack-mount equipment.
Wall-mount your equipment, even if you don't have enough space for a full-sized rack or cabinet. This low-profile server cabinet is perfect for areas where space is at a premium, such as an office. The cabinet saves space by extending only minimally from the wall and housing the length of your equipment vertically. This reduces the horizontal footprint of your equipment while still providing plenty of room for your servers, patch panels, and switches.
To help keep your equipment secure, the vertical server cabinet/network rack features a sturdy metal design and a lock on both the door and access panel. It is also vented, providing passive cooling to help keep your equipment running at suitable temperatures.
The server rack comes fully assembled and includes all of the necessary hardware to install equipment, making installation fast and easy. The mounting holes are spaced 16 in. apart, making it suitable for mounting on almost any wall, based on common North American wall-frame stud spacing.
- StarTech.com 6U Wall Mount Network Cabinet - Vertical Wall Mount Patch Panel Rack - 30" Server Room Cabinet (RK630WALVS) - rack enclosure cabinet - 6U
- Product Type
- Rack enclosure cabinet
- Placing / Mounting
- Wall mountable
- Package Content
- 2 door keys, 24 screws (12-24), 2 front panel keys, 24 plastic washers
- Black
- Height (Rack Units)
- 6U
- Product Material
- Steel
- 64.3 cm x 29.2 cm x 94 cm
- 33 kg
- Lockable front door, adjustable rails, 2 post
- 5-year warranty
- Product Type
- Wall mountable
- Product Material
- Steel
- Package Content
- 6U
- 64.3 cm
- 29.2 cm
- 94 cm
- 33 kg
- Black
- Weight Limit
- 90 kg
- Limited warranty: - 5 years
StarTech.com 12-24 Server Rack Screws - 50 pack - Nickel-Plated | In Stock | £17.19 |
