This USB A Female to Motherboard Header Adapter features a 4-pin USB header connection, as well as a regular USB A (female) port, allowing you to connect internal USB devices directly to the motherboard header connection. The adapter cable offers a cost-effective solution for connecting multi-function front panels, or any device that relies on using an internal USB port.
- StarTech.com 6in USB 2.0 A to USB 4 Pin to Motherboard Header Adapter F/F - USB cable - USB (F) to 4 pin USB 2.0 header (F) - USBMBADAPT - USB cable - USB to 4 pin USB 2.0 header - 15 cm
- USB cable
- Length
- 15 cm
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 4 pin USB 2.0 header - female
- Designed For
- P/N: 35FCREAD, 35FCREADBK, 35FCREADREM
- USB cable
- Length
- 15 cm
- Connector
- Designed For
- StarTech.com 35FCREAD, 35FCREADBK, 35FCREADREM
