Split a single headphone jack into two.
The MUY1MFF 3.5mm Stereo Splitter Cable/Y-cable features one 3.5mm male and two 3.5mm Female audio connectors, splitting a single headphone jack into two.
A practical, cost-effective audio solution, the 3.5mm stereo splitter cable features fully molded connectors with strain relief for long-lasting durability and high quality gold terminals to ensure corrosion-free connections.
Durable construction
The molded design of this audio splitter cable ensures that it can withstand daily use while providing reliable performance. -
Gold plated connectors
Gold plating on the connectors enhances conductivity, resulting in clearer audio during playback. -
Flexible design
With an American Wire Gauge of 26, this cable is flexible, making it easy to route in various setups and environments. -
Multi-device compatibility
This splitter cable can connect to headphones, speakers, and other audio devices, offering functionality for different setups.
- StarTech.com 6 in. 3.5mm Audio Splitter Cable - Stereo Splitter Cable - Gold Terminals - 3.5mm Male to 2x 3.5mm Female - Headphone Splitter (MUY1MFF) - audio splitter - 15.2 cm
- Cable
- Audio splitter
- American Wire Gauge (AWG)
- 26
- Length
- 15.2 cm
- Connector
- Mini-phone stereo 3.5 mm - male
- Connector (Second End)
- 2 x mini-phone stereo 3.5 mm - female
- Moulded
- Limited lifetime warranty
- Designed For
- P/N: MU1MMS, PCISOUND4CH
- Cable Type
- Audio splitter
- 26
- Length
- 15.2 cm
- Plated Connector
- Gold
- Moulded
- Connector
- Limited warranty - lifetime
- Designed For
StarTech.com 3.5 mm to 3.5 mm Audio Coupler - Female to Female | In Stock | £5.47 |
StarTech.com 3.5mm 4 Position to 2x 3 Position 3.5mm Headset Splitter Adapter - F/M | In Stock | £7.79 |
StarTech.com 3.5mm 3 Pin Headset Splitter | In Stock | £3.62 |
StarTech.com Slim Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female | In Stock | £5.05 |
StarTech.com 4 Position to 2x 3 Pin 3.5mm Headset Splitter Adapter - White | In Stock | £3.47 |
