StarTech.com 6in Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female
Quicklinx: 3ZKDWS00 Mfr#: MUY1MFF
Type: Audio
Length: 15.2cm
More than 50 In Stock
£2.74 ex VAT
£3.28 inc VAT
Split a single headphone jack into two.
The MUY1MFF 3.5mm Stereo Splitter Cable/Y-cable features one 3.5mm male and two 3.5mm Female audio connectors, splitting a single headphone jack into two.
A practical, cost-effective audio solution, the 3.5mm stereo splitter cable features fully molded connectors with strain relief for long-lasting durability and high quality gold terminals to ensure corrosion-free connections.
  • Durable construction
    The molded design of this audio splitter cable ensures that it can withstand daily use while providing reliable performance.
  • Gold plated connectors
    Gold plating on the connectors enhances conductivity, resulting in clearer audio during playback.
  • Flexible design
    With an American Wire Gauge of 26, this cable is flexible, making it easy to route in various setups and environments.
  • Multi-device compatibility
    This splitter cable can connect to headphones, speakers, and other audio devices, offering functionality for different setups.
StarTech.com 6 in. 3.5mm Audio Splitter Cable - Stereo Splitter Cable - Gold Terminals - 3.5mm Male to 2x 3.5mm Female - Headphone Splitter (MUY1MFF) - audio splitter - 15.2 cm
Cable
Audio splitter
American Wire Gauge (AWG)
26
Length
15.2 cm
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
2 x mini-phone stereo 3.5 mm - female
Moulded
P/N: MU1MMS, PCISOUND4CH
Cable Type
Audio splitter
26
Length
15.2 cm
Plated Connector
Gold
Moulded
Connector
Limited warranty - lifetime
3ZKD StarTech.com 3.5 mm to 3.5 mm Audio Coupler - Female to Female In Stock £5.47
3ZKD StarTech.com 3.5mm 4 Position to 2x 3 Position 3.5mm Headset Splitter Adapter - F/M In Stock £7.79
3ZKD StarTech.com 3.5mm 3 Pin Headset Splitter In Stock £3.67
3ZKD StarTech.com Slim Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female In Stock £5.05
3ZKD StarTech.com 4 Position to 2x 3 Pin 3.5mm Headset Splitter Adapter - White In Stock £3.51
Type: Audio
Length: 15.2cm
