StarTech.com 6in Stereo Audio Cable - 3.5mm Female to 2x RCA Male
Quicklinx: 9KRMWS00 Mfr#: MUFMRCA
Length: 15.24cm
12 In Stock
£4.38 ex VAT
£5.25 inc VAT
Connect your computer or audio device (iPod, MP3 Player, etc.) to a stereo with standard RCA cables. The MUFMRCA 6in 3.5mm to RCA stereo audio cable features one 3.5mm (TRS) female and 2x RCA male connectors, enabling you to connect your portable audio device (iPod or other MP3 player) to your home stereo. Simply plug your audio device into the female 3.5mm connector using one of the standard male to male 3.5mm stereo audio cables (MU6MMS) and then connect to your home stereo through the two male RCA connectors.
This 3.5mm to RCA Cable is designed and constructed for maximum durability, to ensure dependable, long-lasting connections.
  • Durable construction
    Crafted with a robust PVC jacket, the cable is designed to withstand everyday wear and tear.
  • Clean audio transmission
    The nickel-plated connectors are engineered to reduce interference, delivering sound for an enjoyable listening experience.
  • Easy connectivity
    With color-coded connectors, users can effortlessly match the right connections, making setup quick and hassle-free.
  • Versatile application
    This audio cable serves as a link between mini-phone stereo devices and RCA audio systems, expanding compatibility.
StarTech.com 6in RCA to 3.5mm Female Cable - Audio to RCA Cable - 3.5mm Female to 2x RCA Male - Aux to RCA - Stereo Audio Cable (MUFMRCA) - audio cable - 15.24 cm
Cable
Audio cable
Length
15.24 cm
Connector
RCA x 2 - male
Connector (Second End)
Mini-phone stereo 3.5 mm - female
Colour-coded connectors
P/N: MU15MMS, MU6MMS
Cable Type
Audio cable
Jacket Material
PVC
Length
15.24 cm
Plated Connector
Nickel
Connector
RCA x 2 - male
RoHS
Limited warranty - lifetime
9KRM StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £2.97
9KRM StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
9KRM StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female In Stock £4.25
Length: 15.24cm
