Connect your computer or audio device (iPod, MP3 Player, etc.) to a stereo with standard RCA cables. The MUFMRCA 6in 3.5mm to RCA stereo audio cable features one 3.5mm (TRS) female and 2x RCA male connectors, enabling you to connect your portable audio device (iPod or other MP3 player) to your home stereo. Simply plug your audio device into the female 3.5mm connector using one of the standard male to male 3.5mm stereo audio cables (MU6MMS) and then connect to your home stereo through the two male RCA connectors.
This 3.5mm to RCA Cable is designed and constructed for maximum durability, to ensure dependable, long-lasting connections.
Durable construction
Crafted with a robust PVC jacket, the cable is designed to withstand everyday wear and tear. -
Clean audio transmission
The nickel-plated connectors are engineered to reduce interference, delivering sound for an enjoyable listening experience. -
Easy connectivity
With color-coded connectors, users can effortlessly match the right connections, making setup quick and hassle-free. -
Versatile application
This audio cable serves as a link between mini-phone stereo devices and RCA audio systems, expanding compatibility.
- StarTech.com 6in RCA to 3.5mm Female Cable - Audio to RCA Cable - 3.5mm Female to 2x RCA Male - Aux to RCA - Stereo Audio Cable (MUFMRCA) - audio cable - 15.24 cm
- Cable
- Audio cable
- Length
- 15.24 cm
- Black
- Connector
- RCA x 2 - male
- Connector (Second End)
- Mini-phone stereo 3.5 mm - female
- Colour-coded connectors
- Limited lifetime warranty
- Designed For
- P/N: MU15MMS, MU6MMS
- Cable Type
- Audio cable
- Jacket Material
- PVC
- Length
- 15.24 cm
- Plated Connector
- Nickel
- Black
- Connector
- RCA x 2 - male
- RoHS
- Limited warranty - lifetime
- Designed For
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £2.97 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female | In Stock | £4.25 |
