Connect a Slimline SATA optical drive up to 6in away from a standard SATA motherboard connection. The SLSATAADAP6 Slimline SATA to SATA adapter features a Slimline Serial ATA connector on one end and a standard SATA data connector (with SATA power connector) on the other, enabling you to connect a Slimline SATA optical drive to standard motherboard and power supply connections.
The slim SATA adapter offers 6-inches in cable length, which compared to standard (non-cable) SATA/Slimline SATA adapter reduces strain off the drive connector and allows for flexible cable routing when positioning the Slimline SATA drive within the system case.
- StarTech.com 6in Slimline SATA to SATA Adapter with Power - Slim SATA (F) to SATA (M) - Slimline Serial ATA to SATA (SLSATAADAP6) - SATA adapter
- SATA adapter
- Interface Speed
- Serial ATA 150/300/600
- Connector
- 13 pin Slimline Serial ATA - female
- Connector (Second End)
- 22 pin Serial ATA - male
- Red
- Limited lifetime warranty
- Storage Cable Type
- SATA adapter
- Interface Speed
- American Wire Gauge (AWG)
- 18
- Red
- Connector
- RoHS
