StarTech.com 6in Slimline SATA to SATA Adapter with Power - F/M
Quicklinx: 8D5DWS00 Mfr#: SLSATAADAP6
Length: 15.24cm
Type: SATA
£9.00 ex VAT
£10.80 inc VAT
Connect a Slimline SATA optical drive up to 6in away from a standard SATA motherboard connection. The SLSATAADAP6 Slimline SATA to SATA adapter features a Slimline Serial ATA connector on one end and a standard SATA data connector (with SATA power connector) on the other, enabling you to connect a Slimline SATA optical drive to standard motherboard and power supply connections.
The slim SATA adapter offers 6-inches in cable length, which compared to standard (non-cable) SATA/Slimline SATA adapter reduces strain off the drive connector and allows for flexible cable routing when positioning the Slimline SATA drive within the system case.
  • Reliable connectivity
    Equipped with a 13-pin Slimline female connector and a 22-pin male SATA connector, this adapter ensures a steady connection between devices, facilitating easy data transfers.
  • Efficient data transfer speeds
    Supports Serial ATA speeds of 150, 300, and 600, allowing for rapid data exchange and optimized performance for both storage and retrieval processes.
  • Environmentally compliant
    The adapter meets RoHS standards, which restrict hazardous substances, making it a safe choice for consumers looking to reduce their ecological footprint.
StarTech.com 6in Slimline SATA to SATA Adapter with Power - Slim SATA (F) to SATA (M) - Slimline Serial ATA to SATA (SLSATAADAP6) - SATA adapter
SATA adapter
Interface Speed
Serial ATA 150/300/600
Connector
13 pin Slimline Serial ATA - female
Connector (Second End)
22 pin Serial ATA - male
Red
Storage Cable Type
SATA adapter
Interface Speed
American Wire Gauge (AWG)
18
Red
Connector
RoHS
8D5D StarTech.com 6in Slimline SATA to SATA Adapter with Power - F/M In Stock £9.04
Length: 15.24cm
Type: SATA
