Connect an IDE hard drive to a Serial ATA power connector. The LP4SATAFM6IN SATA to LP4 Power Cable Adapter features an LP4 female power connector and a male SATA power connector, allowing you to connect an IDE hard drive to a Serial ATA power connector provided by the computer power supply.
- StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M - Power adapter - SATA power (M) to 4 pin internal power (F) - 5.9 in - black - LP4SATAFM6IN - power adapter - SATA power to 4 PIN internal power - 15 cm
- Power adapter
- Length
- 15 cm
- Connector
- 15 pin Serial ATA power - male
- Connector (Second End)
- 4 PIN internal power - female
- Black
- Limited lifetime warranty
- Designed For
- P/N: 25S22M2NGFFR, 25SAT22MSAT, HSB225S3R, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SATSASBP425
- Power adapter
- American Wire Gauge (AWG)
- 18
- Length
- 15 cm
- Black
- Connector
- RoHS
- Designed For
StarTech.com SATA to LP4 Power Cable Adapter | In Stock | £4.64 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.22 |
StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M | In Stock | £4.74 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.22 |
