StarTech.com 6in SATA Power to 8 Pin PCI Express Video Card Power Cable Adapter
Quicklinx: 839YWS00 Mfr#: SATPCIEX8ADP
More than 50 In Stock
£4.95 ex VAT
£5.94 inc VAT
Convert two 15-pin SATA power supply connectors to an 8-pin PCI Express video card power connector. The SATPCIEX8ADP SATA to PCI Express Video Card Power Adapter Cable features an 8-pin PCI Express (female) power connector as well as two 15-pin SATA (male) power connectors, providing a cost-effective way to connect a PCIe video card to Serial ATA power connectors provided by the computer power supply - eliminating the need to upgrade the power supply for the sake of video card compatibility.
  • Reliable connection
    This cable adapter features a standard 15 pin Serial ATA power connection to an 8 pin PCI Express power connector, ensuring compatibility with various video cards.
  • Efficient power delivery
    Designed with 18 AWG wire, it provides efficient power delivery to connected devices, enhancing overall system stability.
  • Durable build quality
    Gold plating on connectors prevents corrosion and offers improved conductivity, resulting in a long-lasting and reliable cable.
  • Simple installation
    This adapter is easy to install, making it ideal for quick upgrades or replacements in your computer system.
StarTech.com 6in SATA Power to 8 Pin PCI Express Video Card Power Cable Adapter - SATA to 8 pin PCIe power - power cable - SATA power to 8 pin PCIe power - 15 cm
Power cable
Length
15 cm
Connector
2 x 15 pin Serial ATA power - male
Connector (Second End)
8 pin PCI Express power - male
Power cable
American Wire Gauge (AWG)
18
Plated Connector
Gold
Length
15 cm
Connector
839Y StarTech.com 6in SATA Power to 8 Pin PCI Express Video Card Power Cable Adapter In Stock £4.95
839Y StarTech.com 6in SATA Power to 6 Pin PCI Express Video Card Power Cable Adapter In Stock £4.46
