Convert two 15-pin SATA power supply connectors to an 8-pin PCI Express video card power connector. The SATPCIEX8ADP SATA to PCI Express Video Card Power Adapter Cable features an 8-pin PCI Express (female) power connector as well as two 15-pin SATA (male) power connectors, providing a cost-effective way to connect a PCIe video card to Serial ATA power connectors provided by the computer power supply - eliminating the need to upgrade the power supply for the sake of video card compatibility.
Reliable connection
This cable adapter features a standard 15 pin Serial ATA power connection to an 8 pin PCI Express power connector, ensuring compatibility with various video cards. -
Efficient power delivery
Designed with 18 AWG wire, it provides efficient power delivery to connected devices, enhancing overall system stability. -
Durable build quality
Gold plating on connectors prevents corrosion and offers improved conductivity, resulting in a long-lasting and reliable cable. -
Simple installation
This adapter is easy to install, making it ideal for quick upgrades or replacements in your computer system.
- StarTech.com 6in SATA Power to 8 Pin PCI Express Video Card Power Cable Adapter - SATA to 8 pin PCIe power - power cable - SATA power to 8 pin PCIe power - 15 cm
- Power cable
- Length
- 15 cm
- Connector
- 2 x 15 pin Serial ATA power - male
- Connector (Second End)
- 8 pin PCI Express power - male
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 18
- Plated Connector
- Gold
- Length
- 15 cm
- Connector
