StarTech.com 6in SATA Power to 6 Pin PCI Express Video Card Power Cable Adapter
Quicklinx: 839ZWS00 Mfr#: SATPCIEXADAP
47 In Stock
£4.83 ex VAT
£5.79 inc VAT
Convert two 15-pin SATA power supply connectors to a 6-pin PCI Express video card power connector. The SATPCIEXADAP SATA to PCI Express Video Card Power Adapter Cable features a 6-pin PCI Express (female) power connector as well as two 15-pin SATA (male) power connectors, providing a cost-effective way to connect a PCIe video card to Serial ATA power connectors provided by the computer power supply, and eliminating the need to upgrade the power supply for the sake of video card compatibility.
  • Compatible design
    This cable features a 15 pin Serial ATA power connector that works seamlessly with various power supplies, ensuring versatility in different setups.
  • Efficient power delivery
    With an 18 AWG wire gauge, this power cable minimizes resistance to provide efficient power transmission, keeping your video card powered effectively.
  • Durable construction
    The gold-plated connectors enhance durability and provide better conductivity, promoting long-lasting performance for your components.
  • Convenient length
    At 6 in, this cable length offers just the right amount of flexibility, making it simple to connect components in tight spaces within your PC.
StarTech.com 6in SATA Power to 6 Pin PCI Express Video Card Power Cable Adapter - SATA to 6 pin PCIe power - power cable - SATA power to 6 pin PCIe power - 15 cm
Power cable
Length
15 cm
Connector
2 x 15 pin Serial ATA power - male
Connector (Second End)
6 pin PCI Express power - male
Power cable
American Wire Gauge (AWG)
18
Plated Connector
Gold
Length
15 cm
Connector
839Z StarTech.com 6in SATA Power to 8 Pin PCI Express Video Card Power Cable Adapter In Stock £5.40
839Z StarTech.com 6in SATA Power to 6 Pin PCI Express Video Card Power Cable Adapter In Stock £4.83
