StarTech.com 6in PCI Express Power Splitter Cable
Quicklinx: 7P0WWS00 Mfr#: PCIEXSPLIT6
Length: 15cm
Type: Power
£11.04 ex VAT
£13.24 inc VAT
Split a single PCI Express 6-pin power connection into two power connections. The PCIEXSPLIT6 PCI Express power splitter cable (6-pin to dual 6-pin) lets you connect a single (standard) 6-pin PCI Express power connection provided by the computer power supply to two nVidia SLI or ATI CrossfireX video cards that require a 6-pin power connection.
A cost-saving solution, this PCIe 6-pin to dual 6-pin power cable eliminates the expense of upgrading a computer power supply for the sake of compatibility with dual video card systems.
StarTech.com 6in PCI Express Power Splitter Cable - Power splitter - 6 pin PCIe power (M) to 6 pin PCIe power (F) - 5.9 in - yellow - PCIEXSPLIT6 - power splitter - 6 pin PCIe power to 6 pin PCIe power - 15 cm
Power splitter
Length
15 cm
Connector
6 pin PCI Express power - male
Connector (Second End)
2 x 6 pin PCI Express power - female
Yellow
Power splitter
American Wire Gauge (AWG)
18
Length
15 cm
Yellow
Connector
7P0W StarTech.com PCI Express 6 pin to 8 pin Power Adapter Cable In Stock £9.86
Length: 15cm
Type: Power
