Split a single PCI Express 6-pin power connection into two power connections. The PCIEXSPLIT6 PCI Express power splitter cable (6-pin to dual 6-pin) lets you connect a single (standard) 6-pin PCI Express power connection provided by the computer power supply to two nVidia SLI or ATI CrossfireX video cards that require a 6-pin power connection.
A cost-saving solution, this PCIe 6-pin to dual 6-pin power cable eliminates the expense of upgrading a computer power supply for the sake of compatibility with dual video card systems.
- StarTech.com 6in PCI Express Power Splitter Cable - Power splitter - 6 pin PCIe power (M) to 6 pin PCIe power (F) - 5.9 in - yellow - PCIEXSPLIT6 - power splitter - 6 pin PCIe power to 6 pin PCIe power - 15 cm
- Power splitter
- Length
- 15 cm
- Connector
- 6 pin PCI Express power - male
- Connector (Second End)
- 2 x 6 pin PCI Express power - female
- Yellow
- Limited lifetime warranty
- Power splitter
- American Wire Gauge (AWG)
- 18
- Length
- 15 cm
- Yellow
- Connector
StarTech.com PCI Express 6 pin to 8 pin Power Adapter Cable | In Stock | £8.16 |
