StarTech.com 6in Mini USB 2.0 Cable - A to Mini B
Quicklinx: 76QRWS00 Mfr#: USB2HABM6IN
Length: 15cm
More than 50 in stock
£3.08 ex VAT
£3.69 inc VAT
Optimum file transfer performance of your Mini-USB-equipped MP3 player, PDA or digital camcorder. This USB 2.0 cable provides a high-quality replacement for the cable that came with your Mini USB mobile device. Or, you can keep it as a spare while traveling.
The cable is perfect for connecting devices such as your smartphone, GPS, digital camera, or portable hard drive, to your PC or Mac computer for everyday tasks such as charging, data synchronization or file transfers.
StarTech.com 6 in. USB to Mini USB Cable - USB 2.0 A to Mini B - Gray - Mini USB Cable (USB2HABM6IN) - USB cable - USB to mini-USB Type B - 15 cm
USB cable
Length
15 cm
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
Grey
P/N: USB2002EXT2, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBPLATE4
USB cable
American Wire Gauge (AWG)
30
Length
15 cm
Grey
Connector
USB / USB 2.0, RoHS
Length: 15cm
Stock Status: In stock
