Optimum file transfer performance of your Mini-USB-equipped MP3 player, PDA or digital camcorder. This USB 2.0 cable provides a high-quality replacement for the cable that came with your Mini USB mobile device. Or, you can keep it as a spare while traveling.
The cable is perfect for connecting devices such as your smartphone, GPS, digital camera, or portable hard drive, to your PC or Mac computer for everyday tasks such as charging, data synchronization or file transfers.
- StarTech.com 6 in. USB to Mini USB Cable - USB 2.0 A to Mini B - Gray - Mini USB Cable (USB2HABM6IN) - USB cable - USB to mini-USB Type B - 15 cm
- USB cable
- Length
- 15 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Grey
- Limited lifetime warranty
- Designed For
- P/N: USB2002EXT2, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBPLATE4
- USB cable
- American Wire Gauge (AWG)
- 30
- Length
- 15 cm
- Grey
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com Mini USB to Micro USB Adapter | In Stock | £4.58 |
StarTech.com 6in Mini USB 2.0 Cable - A to Mini B | In Stock | £4.11 |
StarTech.com 6 ft USB Y Cable for External Hard Drive - USB A to mini B | In Stock | £5.00 |
StarTech.com 1 ft Mini USB 2.0 Cable - USB A to Mini B F/M | In Stock | £5.11 |
